Hi all,
I have been researching best ways to fill the gap between the concrete patio and the pavers of my in ground gunnite pool.
Previously, there was a black rubber-like sealant (photo attached) but it was aged and cracking/separating. I cut all of it out and tried using a self leveling sealant (photo attached - gray sealant).
My issue is, that this product I bought came in a tube and the area I have to seal is fairly wide in some areas (up to 3” between concrete and pavers in some areas). In addition, in some areas the concrete patio has dipped down a bit and is no longer the same height as the pavers.
I need a product that is weather resistant, easy to apply and mold to make the transitions smooth, has a mat finish vs the glossy look of the one I tried using, and is flexible for the change in temps.
Thanks in advance for any suggestions.
