Leslie's 3" (3-inch) Jumbo Chlorine Tabs
poolville
6
Weatherford. TX
The following question comes up often with new members to TFP: "What effect does one, 3-inch jumbo Tri-Chlor tablet (or "puck") have on my CYA level?"
The short answer is that you can use the Pool Math calculator to find the answer.
1) Open the Pool Math mobile app.
2) Go to the main menu and select "Effects of Adding" right under "Pool School."
3) Enter your Pool Volume in Gallons.
4) Select "Trichlor" in the "Chemical Additions" field.
5) Type the number 8 in the "Amount" field and change the units to "Ounces" in the drop-down menu.*
[Note: See the bottom of this post for the reference used to determine the number of ounces for each 3-inch Trichlor tablet.]
Example Pool Math results with Leslie's 3-inch, Trichlor, 8 oz tablets on a pool volume of 25,000 Gallons
Effects:
Raise FC by 2.2
Raise CYA by 1.3
Lower pH by 0.1
Raise SALT by 1.8
Check the label info on your Leslie's bucket:
Typically, Leslie's 3" Jumbo Chlorine Tabs contain 99% trichlor active ingredient with 90% available chlorine.
Active Ingredient = Trichloro-s-triazinetrione (Tri-Chlor) Active Ingredient (99%)
*As of Saturday, September 3, 2022, Leslie's website states the following: "Along with our perfected chlorine tab manufacturing process, we ensure the utmost quality in each 8 oz. chlorinating tablet."
Link to 35 pound bucket: Leslie's 3 in Jumbo Chlorine Pool Tabs 35 lbs Bucket | Leslie's Pool Supplies
Reactions: HermanTX
Effects:
Raise FC by 2.2
Raise CYA by 1.3
Lower pH by 0.1
Raise SALT by 1.8
Have a read of the reviews on that Leslies link, one person has been using them for 31 years, another for 25 year. I’d hate to think what their CYA is! :oops:
Bring on those tabs. My pool will eat them for lunch and spit them out. I can burn through CYA like nobody’s business. I am going to start a CYA removal business. Come bring your high CYA water in a tanker and take back as much without.
