Hello,
I had a question about the Kreepy Krauly operation. I started it up, and if I move the hose a bit (in an attempt to get it to go past the 1/3 of the pool that it likes
) it seems to stop it from running. It just sat at the bottom of the pool.
I then moved the hose some more and it started it up again. Does this make any sense? I don't see why it would turn it off/on. Is there some kind of sensor that thinks it has gotten jammed, and turns it off, when I move the hose?
Thanks, Aaron
Thanks, Aaron
