JXI 400 Igniter Resistance
Nkepmkep
5
North Carolina
Does anyone know what the resistance should be on the igniter? My heater quit working and was getting an open, so I installed a new igniter and it’s not working either. I failed to check the resistance before installing, but after failing to light the resistance is open again. I measured the voltage and got a reading of 135ac. Could that be blowing the igniters? Suggestions?
Most parts specs allow a differential of + or - 10%. This would put max voltage at 132 volts. This would put the variance from max voltage at just over 2%. While this would definitely shorten the life of the ignitor somewhat, I don't think that it would be a cause for repeated catastrophic failures. Silicon carbide ignitors are both somewhat fragile physically ( from a physical shock like accidentally bumping it against a hard surface) and also prone to fail from surface contamination before installation (like touching the ignitor surface with your hands).
If you measure any connectivity at all on your ignitor, chances are it is working. When they fail, they crumble apart.
You can check the amperage going to the ignitor with a clamp ammeter or an inline ammeter.
If the amperage is exceeding 5 amps, then the ignitor might be getting too hot from excessive voltage.
You might need a true RMS meter to get a good read on the voltage because of how the 120 volt voltage is supplied when the unit is connected to 240 input supply.
