Sisso?
- cut it down now - and properly kill the roots as well.
Sissoo trees have one of the most invasive roots systems of any tree in our area. It will get in sewer lines, push up concrete walkways and block walls, compromise house foundarions and could compromise your pool structure.
A Sissoo tree get massive (50 feet wide) and has an extensive root system. They are fine for large park and retention areas, but not at all good for our small lots. Even if you trim what you see above ground, the root system will continue to spread.
Living in the Phoenix, Arizona area there is one thing most residents know; finding the right plants for your yard can be difficult. Between the brief freezing temperatures to the blazing hot summers, finding the perfect plants to thrive can be difficult. One of the most prolific trees you can...
www.newheights-tree.com
