Hi all, for the most part, my Jandy palm works doing most things. However, if I want to change the temperature of the spa or pool, I have to adjust it manually at the heater. The heater will not listen to whatever I put into the palm control. It will also not switch between pool heat and spa heat without me manually going to the heater and pressing either one. Any tips on what to do?
