Jandy jxi400 high flue temp
alexpool
3
Michigan
Jandy Aquapure 1400
Hello,
My heater is not working. I've replaced the flue temp sensorm I saw another recent thread about this, and I was hoping to get more insight into what to do now. I have noticed there is water on the floor of the heater and on the concrete pad surrounding it. Does this mean I need a new combustion chamber? What should i do now?
Thank you
@PoolGate recently replaced the heat exchanger in his JXI heater and can describe what is involved.
This is a very involved repair that requires almost the complete disassembly of the heater. It isn't terribly hard, but it is involved. The link posted above outlines most of what you will go through when replacing the heat exchanger.
