Difficult to know without being there.My copper and iron levels always test fine - so you think just debris/pollen?
Post a full set of current test results from one of the recommended testkits.
Test Kits Compared
FC 5.0
CC 5.0
pH 7.8
TA 85
CH 200
CYA 30
Salt (if using a SWG) n/a
Water temperature 80
Yes sorry total chlorine 5.0Are you sure you mean CC is 5.0? Or did you mean TC?
Before we help, we need results from your tests. Pool testing is notoriously wrong and we could do more harm with advice from PS tests.Yea it’s a water test from Leslie’s pool supplies
I agree about getting a test kit. I got the tf pro salt kit before our pool was finished back in May. Our pool was finished on 6/8 and within a few days we had crystal clear water. At first it was a little daunting. But I started with the comparator block test for chlorine and PH. Then every couple of days I would add a test to my repertoire. I can now do all of them in about 15 minutes from memory. A friend asked me how much I liked I spending on Pool chemicals, and I was able to say I barely spend any money on chemicals. I spent upfront for the SwG, muriatic acid is cheap, and so is baking soda. So far that’s all I’ve had to buy except for the ten gallons of bleach. I used five to get it open and kept five if I ever have to slam. The test kit will pay for itself and keep you out of the pool store.Before we help, we need results from your tests. Pool testing is notoriously wrong and we could do more harm with advice from PS tests.
Get a recommended test kit and report back. Link-->Test Kits Compared
