Thanks we have not done that yet. It was set up first last Friday and we are waiting for the pool contractor to show us how to work the equipment.When was the last time you backwashed the filter?
Do that next.
Do that next.
One of your skimmer pictures shows the basket lifted up and debris is bypassing the basket. You may want to clean out both skimmers very well and make sure the basket sits down correctly. Hopefully there isn’t a blockage from that.Thanks we have not done that yet. It was set up first last Friday and we are waiting for the pool contractor to show us how to work the equipment.
Thank you. Photo is after brushing the sides and manual skimming for 30 minutes. Skimmers are suctioning in minimal debris and just swirling not sucking the debris into the bottom of the basket. In other words the suction is not strong enough to capture the debris in the baskets just pulls a minimal amount in and swirls it at the top of the baskets.When i lived on a heavily treed yard, during pollen season I needed to run mine 24/7 and it still didn't keep up.
As is, your pool is off for 16 hours and even with good water movement after that, crud may be stuck to the walls if it dried out any.
Can we see a wide angle pic of the pool running today ? The one return in the pic above seems angled up enough, but sometimes you have to adjust them with the water level. I got a couple inches of rain yesterday and my water movement decreased a bunch.
Thank you- even on high power it is not moving any where near as much as that shown in your photo. I will adjust the returns and see if that helps.There could always be a problem, but floating debris will often continue to float. People always think the skimmers should do way more than they do. They work best when you don't watch them. Lol. Tomorrow the basket is full and only the recent crud is still floating.
The water doesn't seem to be moving much so I would angle the returns up a little more. You don't want any rooster tails but you do want the surface water being pushed.
Look how frequent all these 'waves' are and how yours are much less. (Sorry for the sparkles, we'll get you there too)
Then the slightest breeze will stop moderate water movement in its tracks and pause any skimming for as long as it's breezy.
Thank you. Based on the control panel photo is it possible to replace the pole with a 240 voltage? Is it possible the contractor just put the wrong switch in and that is causing the pump not to get enough power?Your pump breaker is single pole, which means that it is 120 volts.
A double pole breaker looks like below.
A new pool should be wired for 240 volts for all large equipment like pool pumps.
Is 240 volts available in the subpanel?
At full speed, you should be getting at least 70 gpm.
The flow should be very strong with 70 gpm.
The skimmers and returns would have good action.
What does the builder have to say?
Note: Do not change wiring unless you are 100% sure.
