Hi all. My pool has been rock solid until very recently. All levels are pretty spot on, but all of a sudden the water is causing eye irritation. I can't figure out what it is. One person suggested that the non-chlorine oxidizing shock I use might be causing it because some people can be sensitive to it. It's not combined chlorine because it's between 0 and .2. Ph is just right at 7.8. All other numbers are on point. Any help would be appreciated.
12k Above ground
Taylor k-2006 for testing
use NST (non-stabilized chlorine tabs) and liquid chlorine. Use non-chlorine oxidizing shock once a week.
have a poolRX in
Try to keep chlorine at 1 - 1.5 (recommended by poolRX) - chlorine is higher now because I shocked with chlorine shock to try and fix
Free Chlorine - 4.6
Combined Chlorine - 0
pH - 7.8
Total alkalinity - 100
Calcium Hardness - 165
CYA - 43
Copper - .2
CSI - .07
Water temp - 89
12k Above ground
have a poolRX in
Free Chlorine - 4.6
pH - 7.8
CYA - 43
Copper - .2
CSI - .07
Water temp - 89
