Intex sand filter SWG system on sleep mode, but running?
changethursday
Active member
Apr 21, 2021
42
Durham, North Carolina
I have an older ECO 15110 that I got from someone, it seems to be working fine, other than not shutting off. Its my first time with a pool. I aded the salt, ran the pump only for 24 hrs to help circulate and dissolve the salt, tested levels, and we're good. Turned on the SWG to run for 4 hrs (1600 GPH, 5000 Gal pool), and it run fine, no codes. After 4 hrs, it moved to "sleep" mode, but the pump is still running.
Is that correct? I assume the SWG is sleeping, but I thought the pump would also turn off and just run the 4hrs/day? I can't seem to find clarity on this in the manual. It gave me the impression that the pump would shut off, and I can't imagine it wants to run 24/7 without burning out. Help!!
I believe you can set the pump to run for the same amount of hours as the swg.
Does yours only have the key pad or does it have a dial also?
If it’s a combo unit, it should shut off after the 4 hours. What shows on the display?
The code 93 is what shows when it is all done chlorinating, but in my experience it runs for a little while longer then goes to sleep. How long has yours been running with the code 93 showing?
Hmmm. Something wrong there, but I am not mechanically inclined so I couldn’t begin to figure out what.
There is a thread on here about the strange way it must be programmed- lemme see if i can find it....
Typing Investigating GIF by ABC Network
Here u go - post#17👇
