Hi, I have an intelliflo VSF 3hp pump with a separate constant water feature pump that run as needed to run the water feature. I have pantair 420 cartridge filter with inline tab chlorintor and pentair gas heater. I also have a spa with spillway in the pool and a water feature on the side that has a separate pump that i run as needed with no schedule.
I was playing around with screenlogic config on phone and accidently deleted all the pump speed setting that was configured by the installer. I was surprised how easy it is to reset the pump speeds on the app. The only speed I remember is the pool speed, pool high speed and freeze protection. I remember there was more settings on this page but I can't remember them all.
I need help configuring my pump to run efficiently. The pool run for 9 hours a day at 2680 rpm which consumes about 1.2kw. I also need help with other setting on the pump to run the spa, blower, heater and spillway as I have the spillway as a separate feature in the app that can he activated by itself. I attached pictures with the current settings I have.
Is it better to keep it on VS or change it to VSf to control flow not speed?
Any help is appreciated. Thanks
