- Dec 26, 2019
- 1,848
- Plaster
- Pentair Intellichlor IC-40
Alright - Had a severe storm roll through last night, and took a lightning strike near/to my power pole. Not sure what the failure was, as I was not here when they came out to repair, but it was isolated and only affected myself and my neighbor that gets power from the same transformer.
Got home this evening and began checking everything out. Intellicenter controller will not power up. I can run the pumps manually so I've got that going for me.
Here's what I know. When I power the control power breaker off, and back on, a couple of the aux relays will toggle on then off quickly, one time, and that is it. I have checked to see that the control board is receiving 24V and 18V at the appropriate connector pins. Other than that, nothing happens. No display, nothing.
I'm thinking the board is fried. There are no obvious signs of a surge to the board such as a fried trace or a damaged capacitor or other component. But not sure what else it might be. I didn't see any mention of onboard fuses to check, nor did I see anything that looked like a fuse.
Not sure what else to check. Hoping someone has some other ideas of things to look for.
Everything else in the house appears to be fine. I would have thought a surge would have taken out more than just the pool panel, but maybe not.
--Jeff
--Jeff
