We have a small in ground fiberglass pool and would like to add a handrail. The surround deck is azac. We would like have the anchoring hardware be flush as there is an existing flush mount safety cover. Best solution(s)?
But obviously you will have to flush mount the rail connections into the deck and if you can't tie them into the bonding system, you will need to get a railing that is coated and does not need bonding..
