Info on above ground pools with insulated walls
Big Blue 72
In The Industry
Jul 11, 2008
23
I'm interested in finding out about ag pools with insulated walls .I saw one a few years ago and will be replacing my 18 foot round this year, Anybody have one or details on manufacturer. Thanks
Do you mean like the insulated composite wall panels ? I believe optimum and radiant both make one with those.
Without a heat source, it doesn't matter IMO. It will slow down the heat transfer a little and maybe buy an extra day with a couple degrees extra. But then in the same token it will take a little longer to warm up as well.
Most of the heat loss is through evaporation anyway, and while any R value is better than no R value, it's still not much with these pools. (Though the manufacturer will claim otherwise and that the walls also cure world hunger).
What I *do* like them for is never rusting. Get one for that alone.
The doughboy hydrosphere is also constructed like this. There’s also the fox ultimate pool- not sure if it has insulation persay.
The main draw for this style pool in my opinion is the more robust construction of the panels vs usually a single sheet of metal in a standard above ground pool. Not really any insulation value it may provide.
I looked at them (I replaced my pool at the end of last season). I decided against them. The cost was not worth it for me.
Regular and consistent use of a solar cover is your best bet at keeping a pool warm.
Reactions: Mdragger88
