Lately, I seem to have noticed more and more OP's posting lists from their PBs containing In-Floor cleaning systems, Venturi type skimmers and these LeafVac Containment systems all bundled together as an entire cleaning system such as the A&A automatic self-cleaning and circulation systems and the like.
Seems the PBs are really pushing these bundled systems especially in the Texas and Southeastern areas.
IFCS are a perfect way for a pool builder to capitalize on the laziness of a pool buyer to move up one size in his/her Bass boat.
“Sir/madam, the pool cleans itself!”
Personally, with the advent of robotic cleaners like the Dolphins, I think IFCs are a huge waste of money and only add to the plumbing complexity of a pool as well as the potential for leaks to develop. Given how many pool service companies and pool owners will add chemicals directly into their skimmer, plaster damage around the pop-up heads is almost always assured. The IFC's have gotten better but they were really designed for a different age when one only had a single-speed pump at the pad. With modern VSPs, you can easily make an IFC system completely useless by not programming in enough flow from the pump.
You forgot to add the “Mic drop” on your way out.
Yeah, they make the claim that because a vortex is created inside the skimmer that the rotational water flow somehow enhances the draw rate of stuff into the skimmer....I've never seen any independent study of that or even a theoretical explanation as to why that might be so....
Right! AND, let’s not forget about the “vortex” that happens in a toilet bowl that’s all so drawing that someone invented the plunger!
I agree with Matt, even when I think he is wrong, because over time, I have learned he is almost always right..
Who are you and what have you done with Jim?
I read that line to my wife and the explosive fountain of soda out of her nose was quite amusing ... it’s been several minutes now and I think her rolling-on-the-floor laughter is starting to subside ...
.... which will be followed up by random verbal outbursts of “thinks he right” with continued chuckles in the coming weeks.
which is all great of course until the leaks start and then it’s a money pit to try to fix....
And a money pit it is!!!
Here are some photos of my Friends pool that had to have the IFCS abandoned. (I spent weeks managing this project from finding the leak, to filling it back up after the repair. This was AFTER her pool company dragged it out for 2 weeks and was unable to find it.)
The condition of her pool when I arrived...
I knew right away once I arrived where the leak was, bottom step in the IFCS pop-up.
BUT, I had to fill er back up, so the leak detection company could confirm.....
After it was filled back up, I made her call her pool company up and have them do “their thing” to clean the mess up so the leak could be confirmed. (man did that water stink!!)
Me draining the pool the night before, because the repair company was coming in the morning. (Keep in mind, this repair took place in July of AZ heat! Talk about a nail biter with the plaster exposed to sun and heat!)
Repair in progress. (They also found small leaks at the skimmer throat and light niche.)
Pool filled back up, and the maiden voyage of the S300 she had to purchase to replace the now abandoned IFCS.
Now I ask you ladies-n-gentleman of the jury, is that IFCS really worth it? I think not!!!
