My method in the past has been to screw 2" pipe into the skimmer and main drain threads. If I put my cyclone blower directly into the skimmer to blowout the lines, should the filter and pump be plugged or unplugged while blowing?
It seems I should keep things plugged to make sure the water is being purged throughout the entire system and out the pool jets.
I also have a separate valve for the fountain which is above the jets. Once I get all the jets blow-out and plugged, I turn the valve to fountain and get a great deal of water out of it that way.
I am not sure I could still get the water moving out of the fountain if I had the filter and pump unplugged.
My method in the past has been to keep the pump and filter plugged up while I blow-out all the lines. Then my last step is to unplug everything and blow some more from the skimmer line to clear them of any water.
Is this wrong?
The valves show to the left are the skimmer and vacuum lines.
My other issues is that I don't have a valve for the main drain. My method has just been to blow it until I see bubbles then trying to plug it really fast.
This makes me nervous all winter long. I wonder if there is a one-way check valve or something I could attach to my 2" PVC pipe?
Any ideas are welcome
Is this wrong?
