We recently bought a house that has a pool and I'm trying to figure out components.
Does anybody know what these are and what they do?
1st is hose bib above pump. With the hose removed & the pump running when I fully open this nothing comes out ... even though water spa waterfall is spilling water (so the 2 inch line must be full of water and under pressure)!
2nd
A black port in the pool. I appears to be spring loaded but I can't make it open or move in any direction at all. It does not screw in or out either.
3rd is a device below the skimmer basket. It appears to have an o-ring seal interior, It also has a close tab on the bottom - photo 2. When is the close tab on the bottom used vs. just removing the whole thing? BTW, why are there two holes in the skimmer? When I run the skimmer pump it draws only from the bottom hole. Again, why would one close one vs the other hole here?
2nd
