Iaqualink suddenly stopped being able to connect to my wifi HELP
Not sure what type of wifi system you have - can you control or see what things are on the network? If so, turn off the iAquaLink if that is active - then wait a minute or so and switch back on. If that does not work, turnoff the whole AquaLink system - not sure if that is what you meant by turning off the breaker. After shutting down the whole AquaLink box for several minutes then turn it back on and wait at least 5 minutes to see if the wifi connects.
If that does not work - you may need to reset the 2.0 system - there are instructions for that.
I just checked and mine connected so the Jandy AquaLink servers are working therefore it is specific to you wifi or AquaLink system.
