- Jun 24, 2021
- 7,851
- Vinyl
- CircuPool RJ-60
With the influx of springtime new members rolling in, oddly, I found myself astounded at the number of members that have been Pool Stored. I don't know why it struck me this year, after helping so many that have been pool stored in the past, and even having the username PoolStored, but nonetheless, I'm astounded.
Why don't you share your "I knew I was Pool Stored when..." story so members can see we've all been there? I'll go first.
New pool owner during winter (came with the house). Pool Store told me that the UV system needed to be replaced, $1000 ("it will sanitize your pool"). What did I know? (Hint: NaDa). Sure, replace it! They opened the pool, fired up the puck chlorinator, and replaced the UV. I followed their instructions on adding pucks...two weeks later pool turned green. Daily 45 minute trips to the Pool Store (over 10 days) with water samples that turned into daily $50 purchases...clarifiers, algaecides, shock, phosphate removers. At one point I finally realized they had given me the same water results, but a different chemical set. #PoolStored.
TFP and @mknauss saved my pool, and a bunch of $$ over the years. Knock wood, no second SLAMs in my pool.
Share your PoolStored story and who here helped you save your pool, and join #TeamPoolStored, where "The first step is admitting the Pool Store is the problem," and the second step is "Get a good test kit."
If you found value from TFP, please consider becomming a supporter. We are entirely member supported and a non-profit...and no advertising!
Become a TFP Supporter
Help Support TFP Trouble Free Pool is run by a dedicated group of volunteers that … Read more…
www.troublefreepool.com
