- Oct 6, 2021
- 164
- Plaster
- Pentair Intellichlor IC-40
We just had all of the equipment replaced and most of the visible plumbing re-done.
The system seems to run fairly air free, there's just a few bubbles in the pump basket but nothing major. And really no air spurting out of the return jets per se.
However, I've found that there does seem to be some air in the filter. I can bleed off the air a couple times a day. This doesn't seem to affect the pressure reading on the gauge at the filter. But I'm curious where this could be coming from. I think if we had air on the suction side, we'd see lots of bubbles in the pump basket?
And since the filter is the next stop after the pump, does that mean air is getting in at the filter somehow? And for reference, the pump is running around 1700rpm and it took 14-15 sec to bleed it. So it seems to be there's a good amount of air in there.
