Howdy from SE Texas. I’m new to the forum, found it the other night when trying to learn about this wonky thing they call “chlorine lock”. I’ve had my pool nearly 10 years (completed three days after hurricane Ike hit, sept ‘08). My husband and/or I have always done the maintenance. We generally have a gorgeous pool 99.9% of the time. So I’ve never invested in a water testing kit, instead, we’ve taken samples to Leslie’s when we want a real picture. HA!!!
That has generally worked. We don’t buy chems from Leslie’s. Periodically parts, but even rare for that. We
our Amazon Prime. ?
So here we are today. Spring startup. We’ve been swimming since February. Not sure we can call that spring but it’s SE Texas. We did get a TON of rain from Hurricane Harvey last summer (51” in 3 days recorded 0.5 miles from my house). But other than rain, and constant overflow as our drains could not keep up with the amount of water being added, we did not flood. Nothing seemed to go out of whack. About a month ago, for spring startup, we took a sample in for testing. The day before, my boys swam and had major red eye. That NEVER happens for us. Never smell it, never red eye, never blah blah blah. I tell “Marsha” this just as she’s completing the test. And she says “ah-ha, you’re in chlorine lock”. Whothewhatsit? I’ve had this pool for almost 10 years and I’ve never heard of such a thing. I was a chemist for years and never heard of such a thing. So....uh...come again? She says “I can sell you some product but it’s cheaper to drain and refill with fresh water”. She then went on to explain this mythical creature called chrlorine lock. My CYA was “over 99”, the upper limit of their test.
I go home. I drain 1/3. We have a big pool. That hurts. Fill it back up, let it settle for a week, take another sample in. Still “over 99”.
Wash, rinse, repeat.
We've done this 5 times now. As of Monday, they’re now telling us they can run a dilution and pinpoint higher numbers, so my theoretical pinpointed by dilution number for CYA was 130.
I've done research at this point. Surely I’m close. Go home. Wash, rinse, repeat. Tuesday, sample back in. Mind you, I’ve emptied and refilled 1/3 of my 42,000 gallon pool now 6 times. My CYA Tuesday was 180. After being 130 on Monday, emptied by a third, and refilled with fresh, unstabilized water.
Unless my city, in SE Texas, still reeling from hurricane Harvey, is now suddenly stabilizing water. ???
I no longer trust or have confidence in Leslie’s water testing. My water bill is the most expensive it has ever been. Including after the first fill. And the second fill after replastering 2 years ago.
Prior to this, our only “problem” was black mold in our sandstone on our beach entry. We live on a lake, aka a glorified retention pond with pretty lighted fountains. A “lake” filled with untreated, mucky, algae-filled water. Our black mold comes from that. A little bit of shock straight to the beach once a week keeps that from being a problem these days.
And now this CYA problem. Which I now believe is not really the problem I’m being told it is by Leslie’s. But here’s where my questions are starting to come in. I have spent the past couple evenings perusing this website and learning. So...what do I do with my 2 bottles of phos-free that I never needed (and I can vouch for that, as I never used them). What about the hardness issue I now have since so much of my water was dumped down the drain? Anyway to get that back without investing in hardness? I’m also afraid my pH is shot as while my pool is clean, clear, and algae free, I am seeing scaling on our rock water wall. A TF test kit is being ordered and when “I” can do the tests, I’ll post my numbers.
I'm so flipping frustrated that we dumped so much water. Especially after going back in Tuesday and seeing their stabilizer reducer on sale for $40 a bag. A VERY small bag. But we’ve spent $200 on draining and refilling. So a $40 bag wasn’t so expensive after all. What a fool I’ve been. ?
