How to prevent birds from building nests under top rail cap gaps, and stop spiders from building their webs in pool legs?
Crackerjack4u
Platinum Supporter
1,134
Kentucky
This is probably an odd question, but thought I'd ask anyway. I just replaced my pool because the wind destroyed my old one. When tearing down the old pool. A bird had built their nest under about every top rail cap on there.
Also, inside 9 of the actual leg frames that come down from the top rail to the ground, I killed 9 black widow spiders who were living life to the fullest completely concealed in there from view.
I noticed that my new pool also has the wide open gap areas under the caps. The gaps are too wide just to add something like silicone caulking to them. (one would think they'd improved over the years and built those to snap completely closed without a large gap).
I'd like to try to find a way to seal off that gap somehow before a repeat of what happened with the old pool occurs.
Does anyone have any suggestions on how to close off these gaps so the birds and spiders cant set up home in them? Thank you.
I’m having same issues with wasps and small wolf spiders. I actually don’t mind the spiders too much, as long as they mind their own business. Hopefully they’ll eat all the other bugs! But wasps? I hate those with all the passion in my soul. When I see one flying into an upright, I grab the 20 feet wasp spray and unload on that area on both sides of upright.
I‘m reluctant to try to seal area because I don’t want to inadvertently damage it. So I’m still thinking it thru.
Hard to picture in my mind, but look up foam backer rod. If not big enough, how 'bout pipe insulation or pool noodles to fill the gaps?
For bugs, nothing I've used works better than bifen-based Talstar P.
Reactions: Crackerjack4u
I get it, but it's so annoying. I also dont want to damage my new pool, so hopefully someone has a good way to prevent it without any damage.
I've read but never tried tying DVDs or CDs (for those of us old enough to remember them) to the top rail and when wind hits them they spin and flash. Supposedly this scares the birds but again I don't know.
Maybe get this DVD.
We don't mind the birds nesting there (we have a few birdhouses in the yard so, why not?) but when I knew I was going to replace my pool a few years ago we didn't want them to return and nest there in spring only to get torn out.
We filled them up with those light (by weight) lava rocks since we had them around. It worked for the birds, but probably wouldn't keep spiders out.
