Or is that even possible? I've only been BBB for about 2 weeks now, but I'm having to add muratic acid every other day to keep PH in check. It creeps up about 0.2 per day. When it get's up to 7.8, I'll add acid to bring it back down to the 7.3ish range. My TA is 80-90. Of course, I'm having to add baking soda every now and then because the muratic acid is dropping the TA as well. Should I raise my TA to help out with the constant PH increase? If so, to what level? I do have a lot of aeration with the spa spillway running with the filter pump 10 hours a day....plus the kid in the pool a couple of hours a day...plus the waterfall about an hour a day. I don't mind having to add acid to keep the PH in line, but if there is something I can do to cut that down....
Back when I was using trichlor pucks, that would balance out my PH. The trichlor must have been bringing down the PH pretty close to the rate the aeration was raising it. Of course my CYA was increasing every day, but that's another story.
