New pool owner, (40,000 gal in ground vinyl lined) learning crash course style. Had pool guy out to get started, after his visit had trouble keeping chlorine up, turned up dispenser on tablets, figured out mistake later. Now pH stays quite low (6.6 or lower), even with adding chemical, cya levels around 150, chlorine hard to keep up. (All other levels test in ideal range) Read up, see that we need to drain water out and add fresh to lower cya. Planning to drain roughly 30% of water and refill and repeat 2 or 3 times til cya level at 30 to 40 ppm. My questions are is this the right strategy, and what do I need to know about draining and refilling before I make another mistake?!? Thanks!
