Our pool was flooded with salt water from the recent hurricane. Our home is on the water, so I suspect the water table is quite high with the flooding and the higher tides. Of course, my pool looks like the ocean, and I need to restore it. I plan to use the drain and replace method, however, due to all the sediment, I really need to isolate the worst of it towards the deep end so I can pump that out. Is it safe to let the shallow end go slightly dry, or should I leave a foot or two of water throughout the entire pool? I certainly don’t want the pool to “pop.” Is it possible for just one half of a pool to “pop?” The pool is 6’ deep and around 15x30.
Thanks!
Thanks!
