Ah, okay. Well that explains some of the less than average water use I guess.
Not a super "secret" lol, but I still wouldn't mind buying you a brew one of these days.
And we can stay right here in Chandler and not have to drive to Area 51
r.
Matt,Your pool would be an interesting test case for the liquid cover pool products. Because you are able to directly measure the flow of water into your pool on a daily basis, you could apply the liquid to see how well it works. The water needs to be still, no running the pump, but it would be interesting to see if your overnight water use dropped at all with the liquid cover in place.
Then we can add jello powder and see how that works ?
You don’t say where you are in the Phoenix metro area but in the month of July, based on historical Pan evaporation data, you lose about 13” of water in the month of July. If you know your pools surface area, then you can calculate the gallons of water used -
100 cubic feet = 748 gallons
r.Swimming Pool Surface Area Calculator
Pool Resurfacing Pro is the premier pool resurfacing company on the east coast. Providing commercial and residential pool resurfacing, repair, and conversions as well as deck, patio, and plumbing work. Serving the east coast (Pennsylvania (PA), New Jersey (NJ), New York (NY), Florida (FL)...www.poolresurfacingpro.com
How does one find this data for their area? I did a search but no luck (SE VA).
When my neighbors pool guy (a really good guy btw), came over to inspect the installation of my new equipment (for the warranty), he recommended that product to me?
Unless of course, were talking about something like this
Western States, being awash in sunshine but parched for water, have been collecting evapotranspiration data since the early 20th century.
Rob,I see a weekend project in the making. Matt can bring the Jell-O shots, I’ll bring the Corona lights, and you can supply the Kiltlifter. We can all sit by the pool, and every time Matt says something nerdy, we have to do a Jell-O shot. I suspect after about 20 mins we’ll be able to “see” the evaporation of your pool in progress.
Now of course this project is all in the name of science. (At least as far as the wives are concerned)
Seems their automation setups are not actually connected to real equipment. Just software simulators that really don't simulate actual "real" equipment from what I understand.
Western States, being awash in sunshine but parched for water, have been collecting evapotranspiration data since the early 20th century. Where I am, the University of Arizona has maintained a class A Pan evaporation monitoring station since 1894 ... and a second station since 1982 (we love to watch water boil in the sunshine here).
You can try searching the US Geological Survey or NOAA for data but I suspect there isn’t much for Virginia as you guys likely have more precipitation than evaporation.
You can also look at the Engineering Toolbox website to get a formula for estimating your evaporative loss -
Evaporation from a Water Surface
Evaporation of water from a water surface - like a swimming pool or an open tank - depends on water temperature, air temperature, air humidity and air velocity above the water surface - online calculator.www.engineeringtoolbox.com
Right? I was as shocked as you when I first heard that. I envisioned 4 or 5 pools, all with all kinds of equipment running and all connected to various automation systems for continuous testing etc etc.You have got to be kidding me? You mean to tell me they couldn’t walk over to the warehouse shelves and pull off a bunch of equipment to do a mock-up for their tests?![]()
BowserBNot surprising or even big news. The Navy sent submarines to war after Pearl Harbor carrying torpedoes with magnetic exploders and depth keeping gear that had never been tested with a real warhead (or equivalent weight dummy warhead.) The theory was that the torpedoes would be set to a depth to run just under the target ship and explode where the steel was thinner and the ship would break apart. All in theory. Their contact exploders had not been tested either. Bureau of Ordinance blamed the sub commanders and crews for improper maintenance when torpedoes exploded short of the targets. It seems the magnetic field of a steel ship spreads out as you move farther from the north pole, so the magnetic exploders triggered before reaching their target. When they finally disconnected the magnetic exploders, they found they were not getting hits, because the torpedoes ran deeper than they were set for (remember not ever tested with the weight of a warhead in place.) When that was finally fixed, they found that the contact exploders failed. Torpedoes hit but no explosion. Eventually it was found that the contract trigger would crush when it hit squarely on the side of a steel ship, before it could travel back and hit the primer. All along, no full tests by Bureau of Ordinance, and it Admiral Charles Lockwood to order live tests at Hawaii and prove the results to the D.C. "engineers" to get changes made, and it was mid 1943 before the submarine service had fully functional torpedoes. And that was the U.S. Navy and ships of war in wartime. No real tests. Lab only. So it should be only minimally surprising that swimming pool equipment would get only simulations. However, you'd think that someone there at the company would have a swimming pool they could use for field testing equipment, wouldn't you.
