About how fast does your pool water evaporate in the summer??? I'm in AZ and trying to determine the increase in my water bill since its gotten hot outside....... gallons by numbers??? $ amount of water bill increase???
beez74
I'm down the road in Chandler. Just to add to the conversation and to keep you from falling over when you compute and learn your pool's water usage in the summer.
The total surface area of my pool and spa is 678 square feet.
For the 19 days of July, my pool has used 7,193 liters or 1900 gallons, all due to evaporation (no backwash's this month).
Yep, that's about 100 gallons or 13 cubic feet of water per day.
That is about normal for me during the summer months. In the fall it will decrease to approximately 60 gallons a day etc.
So don't be too surprised.
r.
Not sure if that has anything to do with some of the partial shade that the house and the palms provide or not. That would be hard for me to say. Any thoughts about pool shading having a positive effect on lessening evaporation of pool water?That works out to about 1/4” per day ... a bit on the low side for this time of year so good for you!!
Wow, I thought 100GPD was high. But I did confirm that number with some bucket tests that I performed last year and its right in the ballpark, so I'm pretty sure the water meter is accurate.
If you think that is a bit low for our area and the square footage of my pool, I like it.
Thanks Matt....
r.
Thanks. Yes, I do notice that the daily flow rate on the meter does increase when there is a larger diff between the air temp and the water temp. Last few days, Tpool has been high 80s and Tair around 110. I notice it tends to decrease just slightly when we experience our monsoon conditions.Shading can help a lot.
Don’t know how fancy your meter is but if you could track your water usage by hour and correlate that to outside air temperature minus the pool water temperature that would be interesting. You should see the water flow rate jump up when the temperatures invert - Tpool > Tair - and that should happen in overnight hours.
Seasonally, you should se increases in water flow into the pool during the Fall month’s when the evening temperatures drop considerably below the pool water temps. It’s not uncommon in the desert to see a 20F inversion in temperature which drives A LOT of evaporation.
Rob,Between the pool and irrigation, my water use goes up 1k gallons a month for June, July, and August.
Rob,
Only 33 gallons per day loss to evap and including irrigation? Wow, that's fantastic. How are you doing that?Are you using a cover? What is your pools square footage?
I need your "secret". If you give it to me, I promise "Free Beer". Really
r.
Rob,
r.
