I just bought 2 new ones. I want to keep them clean. What the best way to clean n rinse them ?To get the dirt out from the fold cleated is hard.
Is simple green ok to use to clean filters ?
Dishwasher detergent doesn't foam. It's for the dishwasher not the same as dawn for the sink. What’s your thoughts?I wouldn't. It foams. That is why TSP is used.
I just checked on here, I’m not the only nut looking to clean these filter the correct way. I don’t like washing the filter from out to in as your pushing the dirt in. I saw a video guy made a wand with a 360 water spout head connected to hose. It pushes the dirt out. I will use dishwasher detergentDishwasher detergent is fine too.
You can also use a granular phosphate free dishwasher detergentinstead of a hot tub filter cleaner. Automatic dishwasher detergent is designed to cut through grease and oil without promoting foam or suds which is ideal for pool applications. The only concern with automatic dishwasher detergent would be the presence of phosphates which most detergents have. Phosphates are very bad for swimming pools and you should avoid using a detergent cleaner that has phosphates in it as no amount of rinsing of the filter will fully remove the phosphates.![]()
. You are so right. This morning I woke up and said to my self, im overthink this, I’m not making that wand pressure tip. Funny you said that.Not really. The filter stopped the particles so they are on the filter paper. When you flush them from the outside, the dirt they have collected runs off in the water stream. I think you are over-thinking the cleaning of the cartridges. I used the above and around 30-45 minutes later all 4 of my cartridges look brand-new. Also I am not sure how dirty you think these cartridges get. Have you ever cleaned a set before? They are under constant pressurized chlorinated water so what is on them is sanitized. In reality it is "clean dirt".
