I drained, cleaned, and refilled my daughter's 2011 Solana SX (285 gallon) five days ago. Because of electrical problems which I am in the process of trying to fix, it has not been powered up since the refill. Yesterday I saw that the water level had dropped to about an inch below the front left jets. Today the hot tub is virtually drained completely. It is located on a raised deck. The equipment compartment is dry. The only place on the deck where a small amount of water can be seen is at the drain outlet.
I am considering the use of FIX A LEAK (FAL) liquid to try to stop the leak before resorting to more expensive alternatives because I would not know how to do it myself and am a 75 years old geezer. The issues I see with this that I would like your opinions about include the following:
Any thoughts on the source of the leak?
At an apparent loss rate of nearly 2.5 gal per hour, 60 gal per day does it seem that the leak may be too big for the FAL to work?
I live in Michigan so should I wait until spring to try this to avoid freezing and poor curing of the product? The hot tub is one of the few joys that my severely disabled grandson has. It is not a problem until spring to add the well water daily from an inside faucet that allows it to be warmed up.
About no power the current plug is not gfci (outlet is gfci). I am replacing it with a gfci plug like the one recommended by the manufacturer (Watkins) but one for $20 by Superior Electric instead of the recommended one for $123. Does this seem reasonable?
Let me know of considerations I have not mentioned. Your assistance is most appreciated.
