hose size question
pool is 14x14 square 4 deep think 4000 gallons cant remember the sand pump is this
  • The Krystal Clear Sand Filter Pump generates a pump flow rate of 1,200 gallons per hour, ideal for above ground pools. This pump requires virtually no maintenance except replacement of sand every 5 years.
  • Pump Flow Rate: 1,200 gph (4.5 m3/hr). System Flow Rate: 1,050 gph (4.0 m3/hr).
  • Includes: 6-way Valve. Pressure Gauge. Heavy Duty Tank. Strainer Basket. Built-in Timer. Powerful Mot
