Hello everyone,
I have a pool under construction and during excavation there was a lot of water coming up from the ground and my neighbors told me there is a high water table in the community. My neighbor stated you will need a sump pump as they have for their pool and they recently were refinishing their pool and realized the pump had stopped working and there was water all around their pool and the company that was refinishing pool wouldn't complete the work until the pool was completely dry. So they had to replace the pump and it dried up in about 4 days. I told my PB this and he dismissed it saying the pump is not required as once there is water in the pool there is no issue and only if I drain the pool it could be an issue and there is valve in the bottom of the pool that would be opened when the pool is empty to let ground water into the pool when empty. It sounds reasonable but my neighbor is saying I will have major issues with the pump like she did. My PB insists not an issue and he won't even entertain the idea of installing a pump as not needed. Would love some expert advice from this forum. FYI Pool is Gunite. Thank you in advance.
