Help me understand the SWG + options
wverboom
Active member
Aug 1, 2024
31
Spain
Hayward Aqua Rite (T-15)
Hi there,
Since one week I'm running this Hayward Aquarite SWG 50g/h with PH- pump and sonde + Redox sonde.
Is it normal that when the pump runs the values are fine but when the pump stops values drop like crazy as no water if flowing anymore?
Also having a issue with the PH- pump as it was taking more time to lower the PH than the configured standard time. Now I have a AL3 error message. Change the setting so it won't stop anymore but only inform me.
The pump is a fixed value one. What is the best to do here? Make it run longer? And how to clear the AL3 message? Been searching the installation menu but could not exactly find to clear this message.
i
Measurements are only valid when the pump is running.
I know nothing about your pH system.
So i don't worry about those strange values when pump is not running.
PH drops to 3.9 on some occasions as seen on the graph.
Correct
PH where ever the probe is does not measure the pH of the pool water when the pump is off.
You are putting too much expectations of gadgets.
