- Jul 5, 2020
- 29
- Vinyl
- Hayward Aqua Rite (T-3)
So I recently bought a house and it came with a pool. Prior to this I have only experience Intex above ground pools and they are pretty simple. I believe I understand what I am looking at, but want to make sure as I am looking to install a Hayward Heat Pump soon and would like to do everything except the electrical myself.
Looking at the thumbnails below, I have two pumps, a 1HP and a 3/4HP, I believe the 1HP which is on the right on the second picture with the filter basket attached is the pool pump and the one on the left is a dedicated pump for some sort of pool cleaner. The pool has two jets and the skimmer, but it also has another orifice that has a threaded pool return line plug currently in place and I have not touched it. If I am right, when I want to use this pool clean out orifice with a vacuum head or whatever, do I just run the pump pictured with the two hoses coming out of it or do you run them both at one?
Looking at the piping, I am assuming the pipe coming out of the filter head with the open valve is for backwashing the sand filter?
