Have the pump running 24/7 during the slam. If you have a SWG, then turn it off (but I don't think you have one, right?).
If it was really clear after a good swirl, then I'd take that as the reading. It usually turns light pink again after a while, but 3 seconds sound a bit fast.
For the purpose of maintaining slam level, I would rather opt for the lower FC reading than the higher one, and add another gulp of chlorine should that lower reading be below slam level.
EDIT: see next post, I forgot that you are still doing the OCLT
