- Jan 3, 2023
- 54
- Plaster
- Hayward Aqua Rite (T-15)
Hello TFP community,
I am looking for some feedback on Pool Heat Pumps. I am in Central Florida (Ocala) and am looking to extend pool season a bit - right now we only use pool about May through September, with a heat pump should be able to use it year long or if not at least 10 months out of the year.
My pool is only about 11,000 gallons. I'm looking for a heat pump in the 120,000 to 150,000 BTU range. I have been trying to research these different Heat Pumps on the market but can't get much feedback. Also, in comparing, it seems different companies are just stamping their brand on the same physical pool heat pump....
Any feedback on this ExtremepowerUS unit? Its by far the cheapest for the BTU's I can find. On Amazon, only $2,900.00. Also, it looks like the identical unit is being sold on PoolPartsToGo, branded as a Black and Decker. With their 15% off, $3,442.00. The same ExtremePowerUS Heat Pump is also being sold by Home Depot for $3,525.00. But I can't find ANY real good reviews on this unit. There is a hand full on Amazon and a hand full on Home Depot but otherwise there's not a lot on it...
poolpartstogo.com
Any other recommendations? My neighbor has a Gulf Stream Heat Pump he is very happy with. He got a 10 year warranty with it and its made in the USA, he's had it for about 2 years now no problems.
Energy-Saving BLACK + DECKER Pool & Spa Heat Pump 137,000 BTU to Heat 45,000 Gallons
Energy-Saving BLACK+DECKER Pool Heat Pump 137,000 BTU to Heat 45,000 Gallons Economical, energy-saving, and fast-acting, the BLACK+DECKER pool heat pump tops the market in craftsmanship and value. This model reduces costs by using an evaporation condenser built from corrosion-resistant titanium...
XtremepowerUS Pro 137,000 BTU In-Ground/Above Ground Swimming Pool and Spa Electric Heater Pump System 75212-H2 - The Home Depot
The XtremepowerUS 137,000 BTU Pool and Spa Heat Pump with built-in LED Control Interface lets you extend your swim season and provides a reliable and easy solution to heating your swimming pool or spa.
www.homedepot.com
