Hayward Pro Series Sand Filter Issue?
adarameow
11
Jax, FL
Hello,
Just moved into our home with a pool a week ago. I watched some videos on how to operate the Hayward Pro Series sand filter and decided to run a backwash then rinse due to high pressure. The pressure stayed the same so I repeated a couple times. Afterwards, I used my TF100 to test levels and saw I needed to drain some water due to high CYA levels. Utilized the Waste function and started draining but at some point the water stopped. I turned it off, switched back to filter, and while the pump ran as usual, nothing moved in the pool. Attempted another backwash and rinse, pressure stayed high, returning to the filter position still produced nothing. Am I missing something obvious with the filter?
Editing to add: I just opened the little box shaped thing near the pump that has water and a skimmer basket and the basket has melted and broken apart. The water was too hot to touch. I’ve turned everything off.
Welcome to TFP! :wave: It sounds like you might have lowered the water level too much in the pool and lost prime to the pump. When the "pump pot" runs dry for too long, the wet end (pot) of the pump can overheat and yes, can warp/melt. It can also do that to the plumbing connected to it.
Am I understanding that correctly? Feel free to share pics if you would like.
Reactions: adarameow
On a side note, if it's as bad as I believe it to be with no water moving now, time is of the essence to try and prevent an algae bloom if you didn't already have one. You might consider adding some liquid chlorine and brushing it around as best as you can to try and keep the FC level steady. It might take you a day or two to get the system operating again.
That sounds about right. And yes we are having a good bit of algae starting to creep in. I did the pool math app and added chlorine as it said. Would it be best to leave the pump as is, or replace the melted basket and try to re-prime? I have a pool equipment tech scheduled for tomorrow afternoon so I may just keep an eye on the algae and wait but if it’s an easy fix I’d love to avoid the fee.
I suspect your options will be to replace the wet-end that overheated and melted, or just replace the entire pump. We didn't say much about the motor, but it might have overheated as well. Cost of parts can influence which route is a better value. That plus a few bucks to replace any union fitting or plumbing that might have warped as well.
