Hayward Omni Logic "Resume Schedule"?
May 31, 2011
9
Hi all,
Probably a simple question, but it eludes me. I have a new OmniLogic system on my fairly simple setup including lights, heater, and Tristar VS Pump.
I have a schedule set up and working fine to run the pump at different speeds during the day and night. When I need to disrupt this schedule, for example when I vacuum I manually turn the pump to a higher speed, how do I make the system resume its schedule when the vacuuming is complete? Typically I just manually set the pump to where it should be and the schedule takes over again when the pump speed is scheduled to change. Not the end of the world, but I suspect I'm not doing this as intended.
Is this a thing or am I doing what's expected already? Hopefully I've provided enough info.
Thanks for any help.
Do you have an Omnilogic panel, OmniPL, or OmniHub?
You should not be making changes at the pump control panel. All changes in how you want the system to run need to be made through the Omni panel. Is that what you are doing?
