- Apr 25, 2022
- 301
- Plaster
- Hayward Aqua Rite Pro (T-15)
Hi there
I run my filter 24/7 on low - except for each morning when I schedule to high so my pool heater can work. Someone with a pentair system set up a function called ‘heat demand’ where he runs his filter 24/7 and when the heater clicks on, the filter speed changes to accommodate the flow required. Then drops back again when the heater is done. Does Hayward work this way? If so how can I set it up in my omnilogic?
If not - what speed do I need to run my filter for my heater to work? I run it most mornings as I do laps mid morning and I like the water warmed to 87. My scheduling is intense as I need to schedule both the filter abs the heater for different days depending if I swim or not. Would be great to just have the filter on low and then just schedule my heater rather than having to manage both.
Any advice will be gratefully received .
