- Jan 9, 2021
- 135
- Plaster
- Hayward Aqua Rite (T-15)
Hello , if possible to get a quick answare because I’m loosing my mind
I added 3 Hayward bubblers and 3 320 Hayward light that works with the bubbler fitting.
my pool builder install the lines for each bubbler with 1.5” pipe and that’s ok for the bubbler , the problem is the light , he uses 1.25” pipe by mistake and now he said we need to chip down to reach the pipe under the shell and install a fitting to 1.5” that’s the only way to fix the light otherwise I will only have bubblers without it.
to get the bubbler installed we only need to chip 2” down and set the bubbler flush with the concrete (shell) , if I decide to use the light we will have to chip about 9” down change the use fitting to use 1.5” pipe and then fill the big hole with cement then plaster.
my question is, should I let him do it ? Idk if I want to go so deep in order to change the fitting , my shell is 6” and if we cut 9” or more down we will “out of the shell” reaching the dirt and I’m not sure what can happen since the shell was shot and it’s like one piece.
I really appreciate your comment , he want to do it but I’m not sure if I want to let him do it , I can live without the light but I’m so upset about it .
thank you in advance.
