Salt Mode
Aqua Trol is shipped in Normal Salt Mode requiring your pool’s ideal salt level to be 3200 ppm.
To change to Low Salt Mode (1500 ppm ideal level), perform the following steps:
1. Slide the Main Switch from “Off” to the “Auto” position.
2. Push the Diagnostic button repeatedly until “nSlt” appears on the display.
This indicates that the unit is in Normal Salt Mode.
3. Slide the Main Switch from “Auto” to “Super Chlorinate” and back to “Auto”.
The display should toggle to “lSlt” which indicates Low Salt Mode.
4. Do not touch any buttons for 30 seconds and the display will revert back to the current SaltDisplay.
Diagnostic Displays
Sequential pushes of the small “diagnostic” button next to the LCD display will cause the Aqua Trol
to display the following information:
1. Pool temperature (xx degrees Fahrenheit or Celsius)
2. Cell voltage (typically xx.x volts when chlorine is being generated, otherwise 30-35V)
3. Cell current (typically x.xx amps when chlorine is being generated, otherwise 0 amps)
4. Desired Output % (“0P” -- “100P” depending on knob position )
5. Instant salinity ( -xxxx ppm or -x.xx grams/Liter)
6. Product name sent to the display (“AL-6” signifies “Aqua Trol” (STD), (“AL-7” signifies “Aqua
Trol Return-Jet”)
7. Software revision level (r1.xx)
8. Salt Mode (nSlt = Normal Salt Mode, lSlt=Low Salt Mode)
On the 9th push of the button the display will revert back to the default salt display. Also, if the button
is not pushed for 30 seconds, the display will revert back to the standard salt display.
AquaTrol is the affordable salt chlorine generating solution for above ground pools that saves you time and money while conveniently keeping your pool clean and safe.
ca.hayward.com
