- Aug 20, 2018
- 15
- Vinyl
- Hayward Aqua Rite (T-9)
Hello,
I’ve been using this site for a while but this is my first post. I need some assistance. Within the last month I replaced my Tcell-9 and flow switch. I noticed that my water was a cloudy green. I got my water tested yesterday and the results are as follows:
25000 gallon pool
FC: 4.64ppm
TC: 5.1ppm
CC: 0.46ppm
PH: 7.7
Alkalinity: 104ppm
Adjusted Alkalinity: 92ppm
Calcium Hardness: 197ppm
Cyanuric Acid: 39ppm
Salt: 2,723
Diagnostic readings:
Instant salt reading: 3,700ppm
Temp: 79
Volts: 30.2
Amps: 7.02
Filter set at: 100ppm
T Cell: 9
My concern is that the volt and amp readings are high as well as the salt reading compared to the test results. Can anyone provide some guidance on what possibly could be the issue? Your assistance is greatly appreciated.
25000 gallon pool
FC: 4.64ppm
TC: 5.1ppm
CC: 0.46ppm
PH: 7.7
Alkalinity: 104ppm
Salt: 2,723
Temp: 79
Volts: 30.2
Amps: 7.02
T Cell: 9
