- Jun 7, 2017
- 9,958
- Plaster
- Jandy Aquapure 1400
I put a lot of sod (grass) around the pool areas last year. This is getting to be a HUGE pain because the grass blows into the pool/deck when it is cut. It is also a royal pain to cut right next to the aluminum fence since the weedwacker gets hung up on and tears up the fence bottom so can't be used. We end up having to cut all that by hand. The other areas we did not design very "smartly" and they go to a "point" which makes mowing impossible and again, hand trimming when done. I sure would like to just pave everything over and lose the landscaping weekly headaches.
Any ideas of what to do with these problem areas? We get a lot of wind so don't want to just do mulch which I have thought about. One thing I tried and seems to work well is I put a 1x4 pressure treated board under the fence sections so no grass grows directly under it and so I can use the weedwacker easier since it doesn't need to get right up on the fence for what the mower can't get to. I should have gone with a 1x6's and may still do that since I just started that project.
TIA!
TIA!
