- Sep 17, 2022
- 117
- Vinyl
- Pentair Intellichlor IC-40
Hi all, I've got all the stuff to add borates to the pool on order. having researched, couple questions.
I am adding boric acid to the pool. my ph is currently about 7.5. we've had bad weather recently so I havent been able to run the fountains overnight to bring the PH up to 7.6-7.8 where I like to keep it. my question is this.
1. should I bring the ph up to 7.8 because the boric acid will make it drop a bit? It is my understanding that ph is more difficult to change after adding the borates.
2. I saw the recommendation to bring the TA to the low part of the recommended range before adding borates. I did not think that adding the borates did anything to the TA. OR, is this the difference between the Boric acid vs borax method? My TA is currently at 70.
These are two things that have eluded me in my reading.
So, my current plan is to add the full amount of boric acid to the pool with a starting PH of about 7.8-7.9. if the boric acid brings the ph down by 2-3 points, I should be ok. what say you?
