We bought the gazebo pictured below and it will be right at the edge of one end of our pool. I plan to put a TV under the Gazebo, probably 50-60". When it is being used, I'd want it to be about where the window is behind Gazebo in this picture (height-wise) as that would be a good viewing angle (eye-level) for people sitting in the gazebo and would also be easy to see from the pool. BUT because that puts it fairly low and exposes it to the elements, I'm assuming it'd be bad to leave it there all the time and was hoping for a way to "lift it up" to be more under the protection of the roof when not in use. (But also not be in the way of people standing/sitting under the gazebo.)
So far I haven't found any great solutions to that. The Gazebo has a fairly shallow pitched roof. There are some "over fireplace pull down mounts" but those are a) Too big for the application - the mount itself wouldn't fit on the gazebo beam and b) the TV wouldn't go far before the top of the TV would hit the roof of the gazebo and the tv would also be sticking out into the gazebo area. Ideally in my mind the TV would be on some type of hinge mount where it would hang in the right place when being viewed, but when not it would rise up so that the screen was facing the roof of the gazebo and the back of the TV would be high enough overhead to not be in the way.
That was my idea, but I haven't found anything to accomplish that (like a pneumatic arm/mount that would do it) and I figure a lot of people on here probably have TV's under gazebos by the pool and am wondering what y'all have done.
