WE are about to put up our second AGP at a new location and I can't remember how we did it the first time. My husband found these at HD (local store lacking supplies right now.) The didn't have the locking blue foam we used last time.
Can I use this foam board?
Last time we placed the foam and cut the pavers out so legs weren't actually sitting on foam but on the pavers. We had a 16' intex that time, but we bought 18' this time.
Can I mix it with a few old pieces of the blue foam if I need extra pieces to make circle?
Is there a thread somewhere that shows all the actual steps from leveling ground, setting and leveling pavers, setting up foam, then cutting it for pavers?
I am in the arizona mountains and have very rocky hard ground. We dug out a space of 21' feet diameter and had to compact one end with a jumping jack and small retaining wall. at one point the edge of pool will sit at least 3 plus feet from edge of retaining wall at the closest spot, which is only about 1 foot wide.
Thermasheath Rmax Thermasheath-3 1 in. x 4 ft. x 8 ft. R-6 Polyisocyanurate Rigid Foam Insulation Board-787264 - The Home Depot
Visit the Home Depot to buy Thermasheath 3R-5.9 1 in. 4 ft. x 8 ft. Foam Insulation 787264
www.homedepot.com
