Thanks to all who post valuable content. Between TFP and YouTube went from 0 to what I am sharing below in a few weeks. Request is to fill the gaps & recommend additional details.
We are located south of Nashville, TN and have rocky clay soil set near many trees. Freezing temperatures occur for 1-2 months per year and a 1-2 weeks in single digit temps. Vinyl Liner elected based on soil, climate and budget.
Plan: 16' x 32' rectangle (4' stairs end depth sloped to 6' water feature end) Latham 14g steel wall back filled with rock, paver coping / paver patio & 27ml Tara liner. Concrete floor. Steps & bench are liner over Latham steel. Hayward equipment (VSP, 460 sqft cartridge filter, electric heater). Three returns (one loop / line), two skimmers each with dedicated line, two RGB lights, 2'x2'x8' site built stone ledge with 6' wide descent.
Questions for TFP:
- Should I seek 'wide mouth skimmers' OR are two standard skimmers adequate? (lots of leaves)
- Should I increase to four returns with two loops (each loop has 2 returns so if issue could close 1 loop and operate pool)
- Are two RGB lights sufficient? (both pointed away from house)
- For the purpose of simpler chemistry management should I add SWG?
- For a new owner should I avoid automation requiring me to see, smell and touch the pool before adjustments?
(pad will accommodate SWG & automation if not initially added)
- Any major concerns on functional setup based on my attached rough sketch?
- Other than questions to PB below what else should I ask?
Open questions to PB:
Returns
- Can the fittings be 'aimed'?
- Is this a 'looped return system' or 'individually piped'?
Plumbing
- What is the plumbing material? (Rigid or Flexible PVC)
- What is the size of the supply / return lines?
- Are elbows sweep or 90 degrees?
- Is a discharge line at the equipment stack included?
Stairs & Benches
- Is the non-slip (Tara Sure Step) steps?
- Please confirm the structure is steel, backfilled (don't want bounce or echo) & has a foam coat under liner (comfort)
Thanks!
Questions for TFP:
Returns
Plumbing
Stairs & Benches
Thanks!
