Hi everyone,
I'm starting my 4th year as a pool owner. We bought this house with a 25(?) year old pool. I follow only TFP guidelines and I generally use only 12.5% liquid chlorine to keep my chlorine levels correct. Right now, it's too chilly to swim here near Philadelphia, so I'm using some trichlor tablets in a floater to chlorinate since I need to raise my CYA. Right now, I'm around 20, but I'm keeping my solar cover on 24/7 and running my Pentair controller to regulate my solar panels to warm up the water as much as we can. I'll get some CYA if I need to when it's time to swim if I can't raise it quickly enough with the tablets.
My conundrum is this: we opened the pool this year with virtually no problem except these brown stains where debris had settled over winter. In past years, the sun had cleared these spots over a couple of weeks while we slammed during opening. Not this year. I read the older posts about them possibly being metal stains and trying to use calcium tablets or trichor tablets to try test for certain things, but I couldn't get a clear step by step of what I was trying to test for. I also was confused about when my chlorine had to be at zero and when my pH had to be at certain levels.
Right now, here is where my numbers are:
FC 5
CC 0
CA 50
CYA 20
TA 60
pH 6.8 (just recently dropped and I didn't want to change it today in case it needed to be low for the treatment for the stains).
Thank you so much,
Colleen
FC 5
CC 0
CA 50
CYA 20
TA 60
Thank you so much,
Colleen
