Hey all,
First, thank you for this forum. I've learned a lot! I think I'm also very confused. After having some company for the weekend, I noticed that my FC went to 0. I decided to do a SLAM to bring it back to health. Post SLAM, FC levels (once I started measuring again) went from 12 to 5 in 3 24-hour periods with no bathers. So, about 2.33 ppm/day or 0.097 ppm/hour. This was at 30ppm CYA. Today I measured the FC dropping from 7.5 to 5.5 in only 9.5 hours. So, about 0.211 ppm/hour. This was at around 40ppm CYA (which I raised with dichlor in hopes that I could reduce loss).
I've searched a bunch on the forum for the typical FC loss for a spa, but I'm unable to find it. This seems too much though, as I've read that maintenance of chlorine in a spa should only require a couple teaspoons of liquid chlorine a day. I'm going through a lot more than that.
This isn't fun anymore . Most of my interactions with the hot tub are maintaining it but rarely to go in. Please help!
Edit: Forgot to mention: the SPA looks pretty great, and smells fine.
