ETi 400 High-Efficiency Pool Heater pressure drop curve
The people who answer questions are volunteers.
If you find the site to be a good resource, please consider making a donation to help support the site.
Thanks.
It took them a while but yes, they did respond. The response was pretty useless. Here's what I got:
Original question from me was can you provide a water pressure drop curve for the ETi 400 High Efficiency Pool Heater?
Hello, thank you for contacting Pentair, we are sorry for this delay. At this time we are experiencing a higher volume of calls and emails.
Are you referring too the drop in water pressure?
XXX XXXX
Technical Support Representative
Pentair
293 Wright Street
Delavan, Wi, 53115, US
1.800.831.7133 main
My reply
Yes, a chart for the heater pressure drop vs flow. Much like this chart for a filter:
Their reply:
For a Pentair ETi 400 pool heater, the maximum pressure change allowed should not exceed 2" WC (water column), and the minimum running pressure should not fall below 4" WC.
XXX XXXX
Pentair
293 Wright Street
1.800.831.7133 main
pentair.com
My reply:
I am not asking about the gas flow rate or gas pressure.
I am looking for a water pressure drop vs flow rate for the Eti400 High Efficiency Heater similar to what is shown in the picture below. (refers to the previous pressure drop curve that I sent them)
Their reply:
I am now seeing this information. I can keep looking what type of pump do you have and speeds do you run?
XXX XXXX
Pentair
293 Wright Street
1.800.831.7133 main
pentair.com
My reply:
The type of pump that I have should not have any bearing on this request for the pressure drop curve of the heater.
But to satisfy your curiosity I have a Pentair IntelliFlo3 Variable Speed & Flow Pool Pump. It can operate between 35 RPM and 3450 RPM.
I would appreciate it if you would please keep looking for this information.
I haven't had any further response since April 16th, doubt that I ever will.
Send this:
_________________________________________________________________
This is the head loss curve for your Ultratemp heater.
Please send the head loss curve for the ETi 400 High-Efficiency Pool Heater.
If you do not understand the question, please ask someone who does.
